Why are you recompiling the message bus? What is the use case that you have that is not supported in our release build?
* setting up message bus for running ZeroMQ example usage
OS version:
* Ubuntu 20.04.4 LTS
Kernel version:
* 5.13.0-44-generic
CMake version:
cmake version 3.15.0
Has you completed all the ‘Dependency Installation’ steps? Any error or warning?
Yes, I am following the step stated in this link: https://open-edge-insights.github.io/3.0/pages/msgbus.html
There is no error/warming until the compilation step.
On the compilation, are you using any of the flags(-DWITH_PYTHON, -DWITH_GO, with Debug, etc)?
The first attempt, I without using any flags. After I failed I added -DWITH_PYTHON
Can you also attached along the error log?
Attached
I see the error: cannot find -lpthreads
That library could be missing. can you search for the pthreads library on your system: apt-cache search pthreads
Sincerely,
Sahira
