Intel® Edge Software Hub
Get help on building Edge Software Hub solutions for edge compute node
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
318 Discussions
Failed to execute script docker-compose
HuynhVanThuan
I am having problems with provison, build and run docker-compose when i am trying to inference EII. Can you help me with this problem?
Regard,
Huynh
JesusE_Intel
Hi Huynh,
I believe your docker needs to have elevated permissions, please try to use sudo or add your user to the docker group and set the permissions accordingly.
Also, Edge Insights for Industrials v2.6.3 is only supported on Ubuntu 18.04. If you want to continue using Ubuntu 20.04, you can use Edge Insights for Industrial v3.0. See system requirements for additional information.
Jesus
JesusE_Intel
Hi Huynh,
Jesus
JesusE_Intel
