Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
396 Discussions
[INTEL][Edge Insights for Vision] Install fail with the latest version 21.3
RWu
When installing the latest version 21.3, the module " edgex foundry" is always install failed. The error as below:
nstalling edgex_foundry
Installing EdgeX. This step may take approximately 5 mins.
Installing EdgeX                                   [.................................                 ]  66%  00:00:00
Error:Failed to build docker image
Failed command:sudo -E docker-compose pull
Failed to install edgex_foundry took 2.14 seconds
Is anyone can help?
Thank you.
JesusE_Intel
Hi RWu,
I just installed Edge Insights for Vision 2021.3 release without any issues. Are you still experiencing the same issue?
Jesus
JesusE_Intel
Hi RWu,
Thanks for reaching out, could you please provide additional information.
  • What OS are you using?
  • Is your system using a proxy?
  • Does the system have a fresh OS install?
Also, please share the installation log file for edgex. You can find the log file at the following location:
/var/log/esb-cli/Edge_Insights_for_Vision_2021.3/edgex_foundry
Jesus
RWu
Hi Jesus
  • What OS are you using?   : Ubuntu 18.04.5
  • Is your system using a proxy? : No
  • Does the system have a fresh OS install? : Yes
And the file "install.log" in the path "/var/log/esb-cli/Edge_Insights_for_Vision_2021.3/edgex_foundry" is in attachment.
Nadia_J_Intel
Hi Richard,
We can observe this issue as well and has escalated this to our engineering team to check. We will get back to you once we found a way to solve this issue.
RWu
Hi Nadia,
Thanks for forwarding this problem. Is any workaround or update about this installing fail ? We are trying to test the latest version  on our environments.
Regard,
KunyangF
Hi Jesus,
We have the same problem when installing 2021.3 version, and have the same installing error log in the attachment.
Regard,
Kunyang
JesusE_Intel
Hi Kunyang,
Apologies for the inconvenience, Nadia has escalated the issue to the engineering team.
We will update this thread as soon as we have an update.
Jesus
JesusE_Intel
Hi RWu,
Jesus
JesusE_Intel
