Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
405 Discussions
Incomplete shapes that causes TLS SSD-Resnet50 Object Detect Training Stops
Lin__Joey
Innovator
Dears,
I have encountered TLS object detect training failure, using typologies other than SSD-MobilenetV2.
The attached log was recorded from the SSD-Resnet50 training failure.
Please help to investigate it.
Joey
JinPei_N_Intel
Hi Joey,
For the SSD resnet, there is having some limitation and causes the training failed.
Regards this ,we are still debugging the issue. In the meanwhile, could you try with other model first?
Will keep you update once we have solution for it.
Thanks and sorry for the inconvenience
