Hi all,
I am trying to install the latest "Edge Software Configurator" with version 21.2 in the local device.
But it is always fail with error log as below. The total logs are compressed in the attachment "
ERROR: Some components of Edge Software Configurator failed to start successfully: rni_smb_1
Mon Jul 12 10:34:44 IST 2021 - ERROR - Failed to install Edge_Software_Configurator took 38 minutes 54.99 second
Hi Nadia,
It is work. After closing samba service (port 445) and re-install. The Edge Software Configurator can word.
Best regard,
Kunyang
May I know if you install the latest version of ESC from this link ? https://software.intel.com/iot/edgesoftwarehub/download/home/edge_software_configurator
Does the version 21.2 mentioned above is the same version as the link that I provided here ?
Hi Nadia,
Yes, it is. The version name is popup in the below message when installing
ESB CLI version: 2021.2
Target OS: Ubuntu 18.04
Best regard,
Kunyang
Hi Kunyang,
If you reboot the system and re-initiate the ESC installation, does the issue still the same ?
Hi Nadia,
Thanks for your reply. It is still fail even reboot the device. And I check out the log as below, it seems something was missed.
Wed Jul 14 10:13:28 IST 2021 - ERROR - Following components not found: rni_smb_1
Wed Jul 14 10:13:28 IST 2021 - ERROR - Some components of Edge Software Configurator failed to start successfully: rni_smb_1
Wed Jul 14 10:13:28 IST 2021 - ERROR - Setup Failed
Hi Kunyang,
We're looking on this matter. Will update on this once we found the solution.
Hi Kunyang,
May I know if the ESC is being installed on fresh Ubuntu system ? If not, please check if either the port 445 is already being used by running this command: $sudo netstat -plnt
If something else is using this port, this could be the cause of failing installation due to rni. You can try to reinstall the ESC to a freshly installed ubuntu.
Hi Nadia,
Best regard,
Kunyang
