Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
Intel oneAPI Debian Repo
MohammedSaif
Hi there,
I'd like to install this reference implementation. However, I getting an error whilst attempting to install it. Error being:
saif@saif-Latitude-7520:~/Desktop/4thLPR/automated_license_plate_recognition$ ./edgesoftware install
[sudo] password for saif:
Please enter the Product Key. The Product Key is contained in the email you received from Intel confirming your download: cf9f1425-d1e3-48c9-837f-a89f8bec9d9b
Starting the setup...
ESB CLI version: 2022.3
Target OS: Ubuntu 20.04
Python version: 3.8.10
Checking Internet connection
Connected to the Internet
Validating package product key
Successfully validated Product Key
Checking for prerequisites
E: Repository 'https://apt.repos.intel.com/oneapi all InRelease' changed its 'Label' value from '' to 'Intel oneAPI Debian Repo'
Failed to update apt list. Exiting installation.
Any suggestions?
JesusE_Intel
Hi MohammedSaif,
Thanks for reaching out, I just went through the installation process on a fresh Ubuntu 20.04 system and did not run into any issues. Have you installed any of the oneAPI software on this system? You should also see this error when running apt update. Maybe you can check the following source files and comment out the oneAPI repositories and try the installation process again.
/etc/apt/sources.list
/etc/apt/sources.list.d/*.list
Jesus
JesusE_Intel
Hi MohammedSaif,
Jesus
kharo22
Hello
I have the same issue
current oneApi.list contained
deb https://apt.repos.intel.com/oneapi all main
what value should it contain please ?
thanks
JesusE_Intel
GeorgeBisbas
doing:
`sudo apt-get --allow-releaseinfo-change update`
as in https://github.com/intel/compute-runtime/issues/295
should be enough.
Best,
George
kharo22
Hi
ok my issue is due to  the saved keys were expired
so doing only a
curl -fsSL https://apt.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB | sudo gpg -q --yes -o /etc/apt/trusted.gpg.d/intel.pgp
and explain it to apt with  `/etc/apt/source.list.d/oneApi.list`
`deb [signed-by=/etc/apt/trusted.gpg.d/intel.pgp] https://apt.repos.intel.com/oneapi all main`
and then apt update is working again
So sometimes we need to update  /etc/apt/trusted.gpg.d/intel.pgp
within the above command.
thanks
that's clear now
