Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
404 Discussions
Inventory details not updated while simulating Automated Checkout RI Scenarios
chiao
Hi
I deployed the Automated Checkout RI in Azure EFLOW, it can successfully run on the machine, but failed in simulating using the automated script or curl REST API calls.
please refer to the attached files, thanks!!
BR,
Denise
SShan_Intel
Hi Denise,
Sorry for late response. From the screenshot I notice that you running summary.py in your local NUC device, could you try to run in eflow device?
SShan
JesusE_Intel
Hi chiao,
Please allow us to investigate this issue. I verified the reference implementation is working as expected when deploying on my local system.
Jesus
chiao
Hi Jesus,
I deployed the Automated Checkout RI in the Linux environment and had the same problem.
Please refer to the attached files, thanks!!
BR,
Denise
SShan_Intel
Hi Denise,
SShan
JesusE_Intel
