Hi sagi-scalers-ai,
Thanks for reaching out! Edge Insights for Industrial has not been validated with OpenVINO 2022.3.0. I can submit a feature request for the development team to consider upgrading the OpenVINO version.
That being said, you can try to update the OPENVINO_IMAGE variable by modifying the .env file under <installation location>/edge_insights_industrial/Edge_Insights_for_Industrial_3.0.1/IEdgeInsights/build. You will also need to update a couple of Dockerfiles to update the new location of the OpenVINO setupvars.sh as it has changed in newer releases. The new location is /opt/intel/openvino/setupvars.sh. Previously, it was /opt/intel/OpenVINO/bin/setupvars.sh.
Once the variable has been updated, run python3 builder.py in the build directory followed by the commands shown in the output.
Also, in the latest release of OpenVINO, OpenCV is no longer included. This will require you to update the Dockerfiles to include OpenCV. There may be additional changes needed to update the OpenVINO version on EII.
Hope this helps!
Jesus
