Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Multiple modules failed to install.
EIS installer,Training and learning suite,rotor bearing defect detector failed to install. I have tried many times but have not been successful. The current problem is as follows.
Highlighted
Hi @liu__feifei
Thank you for reporting this issue, can you help to give us for each of the failing components so that we can help to see the detail of the error.
you can check the log by using the below command
$ ./edgesoftware log <componentID>
Highlighted
The log is as follows, please help me.
Highlighted
Hi @liu__feifei
For the Rotor bearing issue, seems like now you are building for video-streaming use case and all the time-series component is not up that cause the Rotor Bearing Defect component failed to install. If you want to change to time series use case and run the Rotor Defect component, you can change the use_case parameter in config_install.yml to 'time-series'.
For the other two issues, seems like you are having a proxy problem, do you run behind a corporate proxy? If yes, you need to set the corporate proxy in your environment before installing those components.
after setting up your proxy, you can try to install again the component.
Highlighted
Can the other two modules be installed without proxy service?
Or how can I install them without proxy service?
Highlighted
Now I have encountered a new problem, as follows
I tried to solve it through the following methods, but failed.
git config --global http.postBuffer 524288000
git config --global http.lowSpeedLimit 0
git config --global http.lowSpeedTime 999999
 Log is as follows, Can someone help me?
Highlighted
Hi @liu__feifei
It is not an error, it will take some time to download depends on your connectivity.
