Intel® Edge Software Hub
Get help on building Edge Software Hub solutions for edge compute node
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
304 Discussions
Multiple version changes of EIS
Snehal_Yesugade
Hi
Recently EIS 2.3.3 version got released, now we do not find 2.3.2 to download from website.
So is it ok to use previous dump of 2.3.2 on different machines with same product key?
Or will it create problem if any of such two machines come in same network?
WengWai_C_Intel
Hi @Snehal_Yesugade ,
Yes, you can use the same product key for all the version of EIS download from Edge Software Hub. The EISv2.3.3 is just a minor hotfix to upgrade the python pip installer to address the 3rd party component build failure issue earlier compare to EISv2.3.2 and the rest are all the same. So, there should be no problem for the machines build with either version come in same network.
