Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
Realsense D435 Issue
DarkHorse
My customer has been seeing these issue with the following hardware settings:
  1. IPC model: Vecow Industrial PC SPC-5600A (Core i7)  https://www.vecow.com/dispUploadBox/PJ-VECOW/Files/5048.pdf
  2. Camera model: Intel Realsense D435
  3. USB model: 3.1 A-C Dual Screw Black Newnex Black 5m 2.0 #U3S1A01C12-050 https://www.newnex.com/usb-type-c-cables-legacy.php
  4. AMR1: 1x D435 connected to IPC USB port type: 2.0; 1x D435 connected to IPC USB port type: 3.2
  5. AMR2: 2x D435 connected to IPC USB port type: 3.2
Ubuntu 18.04.5
Kernel 4.15.0-112-generic
RealSense ROS v2.3.2
LibRealSense v2.50.0
Device FW version: 05.13.00.50
The issues that they are seeing are:
  1. 100% hang if loading the DefaultPreset_D435.json file.
  2. Occasionally (less than 10%) not able to get data from D435 after a stop-start.
  3. Occasionally Ubuntu OS freeze (less than 10%) after a stop-start.
  4. Occasionally hang when start camera node in ROS function.
Please advise on this .
Sahira_Intel
Can you you/your customer please open a thread in the RealSense community and we can certainly help them there.
Sincerely,
Sahira
