Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
405 Discussions
Timeout issue on webvisualizer UI
Snehal_Yesugade
We have CSL network with server - node1 - node2
Whenever we tried to increase number of ingestions, we could observer that connection to webvisualizer based UI gives timeout (while connecting with virtual IP:31505)
We could see below message for wget
"HTTP request sent, awaiting response....read error(connection reset by peer) in headers.
Retrying"
WengWai_C_Intel
@Snehal_Yesugade
As WebVisualizer is being setup as secured connection using https, you should run the wget command with https instead of http. Below is an example:
wget <https://CSL_virtual_IP:31505> --no-check-certificate
WengWai_C_Intel
@Snehal_Yesugade
JesusE_Intel
