We have CSL network with server - node1 - node2
Whenever we tried to increase number of ingestions, we could observer that connection to webvisualizer based UI gives timeout (while connecting with virtual IP:31505)
We could see below message for wget
"HTTP request sent, awaiting response....read error(connection reset by peer) in headers.
Retrying"
As WebVisualizer is being setup as secured connection using https, you should run the wget command with https instead of http. Below is an example:
wget <https://CSL_virtual_IP:31505> --no-check-certificate
