Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
401 Discussions
Training Stopped due to exceeding memory limit for $group
Lin__Joey
Innovator
Dears,
This is a native version of DLS on a fresh installed Ubuntu 18.04. I had succeed with a
200 skin tumor object detection training using CPU. This time, however, it fails on a 600+ fire & smoke object detect training images with an error, showing "exceeded memory limit...". Please see attached screen shot for details.  The model selected and setting are same for both projects.
Joey
JinPei_N_Intel
Hi Joey,
May i know your hardware spec?
Jin Pei
Lin__Joey
Innovator
Dear JinPei
Intel® Core™ i5-7500TE (2.3 GHz, quad-core, TDP=35W)
●Chipset: Intel® Q170
●System Memory:
2 x 260-pin DDR4 SO-DIMM, pre-installed one 8GB (system max: 32GB)
●Power:
Input - DC Jack: 9 V~36 V DC, Terminal Block: 9 V~36 V DC
Consumption: 19 V@3.68 A (Intel® Core™ i7-6700TE with 8 GB memory)
Internal Connector: 5V@3A or 12V@3A
●Reliability:
Operating Shock - Half-sine wave shock 5G; 11ms; 100 shocks per axis
Operating Vibration - MIL-STD-810G 514.6 C-1 (with SSD)
Safety/EMC - CE/FCC
●IPMI: 1 x iRIS-2400 (optional)
JinPei_N_Intel
Hi Joey,
Do you mind capture the memory usage while running the training?
It seems like is hardware limitation, but i would like to further debug before have a conclusion on it.
