Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
401 Discussions
Training and Learning Suite (TLS): Failed to run docker containers after installation
huang06
Software: Edge_Insights_for_Industrial_2.3.2
OS: Ubuntu 18.04.5 LTS
I follow the instructions of README.md and install tls-related images, but I fail to run all the tls containers.
Following are the logs of the exited containers.
$ sudo docker-compose ps
    Name                  Command               State                                                          Ports
tls_apiui      ./webservices/start.sh           Exit 0
tls_core       ./start.sh                       Up
tls_mongo      docker-entrypoint.sh --ssl ...   Up       127.0.0.1:27017->27017/tcp
tls_openvino   /bin/bash                        Exit 0
tls_proxy      /docker-entrypoint.sh /bin ...   Exit 0
tls_rabbitmq   docker-entrypoint.sh /init ...   Up       0.0.0.0:15672->15672/tcp, 0.0.0.0:1883->1883/tcp, 25672/tcp, 4369/tcp, 5671/tcp, 5672/tcp, 0.0.0.0:8883->8883/tcp
tls_redis      docker-entrypoint.sh sh st ...   Up       127.0.0.1:6379->6379/tcp
$ sudo docker-compose logs tls_apiui
Attaching to tls_apiui
tls_apiui       | wait-for-it.sh: waiting for tls_mongo:27017 without a timeout
tls_apiui       | wait-for-it.sh: tls_mongo:27017 is available after 0 seconds
tls_apiui       |
tls_apiui       | > tls-ui@2020.6.11 start /home/tls/webservices/ui
tls_apiui       | > node tools/start
tls_apiui       |
tls_apiui       |
tls_apiui       | > apiserver@0.0.0 start /home/tls/webservices/apiserver
tls_apiui       | > NODE_ENV=production PRIVATEKEY=rsa.private node app.js --use_strict
tls_apiui       |
tls_apiui       | debug: Please note: since `sails.config.session.cookie.secure` is set to `true`, the session cookie
tls_apiui       | debug: will _only_ be sent over TLS connections (i.e. secure https:// requests).
tls_apiui       | debug: Requests made via http:// will not include a session cookie!
tls_apiui       | debug:
tls_apiui       | debug: For more help:
tls_apiui       | debug:  • https://sailsjs.com/config/session#?the-secure-flag
tls_apiui       | debug:  • https://sailsjs.com/config/session#?do-i-need-an-ssl-certificate
tls_apiui       | debug:  • https://sailsjs.com/config/sails-config-http#?properties
tls_apiui       | debug:  • https://sailsjs.com/support
tls_apiui       | debug:
tls_apiui       | Warning: connect.session() MemoryStore is not
tls_apiui       | designed for a production environment, as it will leak
tls_apiui       | memory, and will not scale past a single process.
tls_apiui       | Browserslist: caniuse-lite is outdated. Please run next command `npm update`
tls_apiui       | (node:40) DeprecationWarning: Tapable.plugin is deprecated. Use new API on `.hooks` instead
tls_apiui       | Starting the development server...
tls_apiui       | error: Bootstrap encountered an error: (see below)
tls_apiui       | error: Failed to lift app: Error: getaddrinfo EAI_AGAIN cvat cvat:8080.
tls_apiui       |     at generateError (/home/tls/webservices/components/cvat/cvat-core/src/server-proxy.js:26:16)
tls_apiui       |     at Object.login (/home/tls/webservices/components/cvat/cvat-core/src/server-proxy.js:158:27)
tls_apiui       |     at process._tickCallback (internal/process/next_tick.js:68:7)
tls_apiui       |
tls_apiui       | ┌───────────────────────────────────────────────────────┐
tls_apiui       | │                npm update check failed                │
tls_apiui       | │          Try running with sudo or get access          │
tls_apiui       | │         to the local update config store via          │
tls_apiui       | │ sudo chown -R $USER:$(id -gn $USER) /home/tls/.config │
tls_apiui       | └───────────────────────────────────────────────────────┘
$ sudo docker-compose logs tls_openvino
Attaching to tls_openvino
$ sudo docker-compose logs tls_proxy
Attaching to tls_proxy
tls_proxy       | 2020/11/05 08:58:46 [emerg] 11#11: host not found in upstream "cvat" in /etc/nginx/nginx.conf:52
tls_proxy       | nginx: [emerg] host not found in upstream "cvat" in /etc/nginx/nginx.conf:52
tls_proxy       | # Copyright (c) 2020 Intel Corporation.
tls_proxy       |
tls_proxy       | # Permission is hereby granted, free of charge, to any person obtaining a copy
tls_proxy       | # of this software and associated documentation files (the "Software"), to deal
tls_proxy       | # in the Software without restriction, including without limitation the rights
tls_proxy       | # to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
tls_proxy       | # copies of the Software, and to permit persons to whom the Software is
tls_proxy       | # furnished to do so, subject to the following conditions:
tls_proxy       |
tls_proxy       | # The above copyright notice and this permission notice shall be included in
tls_proxy       | # all copies or substantial portions of the Software.
tls_proxy       |
tls_proxy       | # THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
tls_proxy       | # IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
tls_proxy       | # FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
tls_proxy       | # AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
tls_proxy       | # LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
tls_proxy       | # OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
tls_proxy       | # SOFTWARE.
tls_proxy       |
tls_proxy       | worker_processes 4;
tls_proxy       |
tls_proxy       | events { worker_connections 1024; }
tls_proxy       |
tls_proxy       | pid        /tmp/nginx.pid;
tls_proxy       | http {
tls_proxy       |     proxy_buffering off;
tls_proxy       |     client_body_buffer_size 10m;
tls_proxy       |     client_max_body_size    10m;
tls_proxy       |
tls_proxy       |     client_body_temp_path /tmp/client_temp;
tls_proxy       |     proxy_temp_path       /tmp/proxy_temp_path;
tls_proxy       |     fastcgi_temp_path     /tmp/fastcgi_temp;
tls_proxy       |     uwsgi_temp_path       /tmp/uwsgi_temp;
tls_proxy       |     scgi_temp_path        /tmp/scgi_temp;
tls_proxy       |
tls_proxy       |     limit_req_zone $request_uri zone=by_uri:10m rate=30r/m;
tls_proxy       |
tls_proxy       |     server {
tls_proxy       |         listen 443 ssl;
tls_proxy       |
tls_proxy       |         add_header X-Content-Type-Options "nosniff";
tls_proxy       |
tls_proxy       |         ssl_certificate /run/secrets/tlsserver_cert;
tls_proxy       |         ssl_certificate_key /run/secrets/tlsserver_key;
tls_proxy       |
tls_proxy       |         ssl_session_cache shared:SSL:30m;
tls_proxy       |         ssl_session_timeout 30m;
tls_proxy       |         ssl_session_tickets on;
tls_proxy       |
tls_proxy       |         location /cvatapi/ {
tls_proxy       |             proxy_pass http://cvat:8080/;
tls_proxy       |             proxy_pass_header       X-CSRFToken;
tls_proxy       |             proxy_set_header        Host $http_host;
tls_proxy       |             proxy_pass_header       Set-Cookie;
tls_proxy       |
tls_proxy       |             proxy_set_header Accept-Encoding "";
tls_proxy       |             sub_filter_types *;
tls_proxy       |             sub_filter /static/ /cvatapi/static/;
tls_proxy       |             sub_filter "/static/" "/cvatapi/static/";
tls_proxy       |             sub_filter "/dextr" "/cvatapi/dextr";
tls_proxy       |             sub_filter /api /cvatapi/api;
tls_proxy       |             sub_filter_once off;
tls_proxy       |         }
tls_proxy       |
tls_proxy       |         location /api/v1 {
tls_proxy       |             proxy_pass http://cvat:8080;
tls_proxy       |             proxy_http_version 1.1;
tls_proxy       |             proxy_set_header Upgrade $http_upgrade;
tls_proxy       |             proxy_set_header Connection "Upgrade";
tls_proxy       |             proxy_set_header Host $host;
tls_proxy       |             proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
tls_proxy       |             proxy_set_header X-Forwarded-Proto $scheme;
tls_proxy       |         }
tls_proxy       |
tls_proxy       |         location /socket.io/ {
tls_proxy       |             proxy_pass https://tls_apiui:1337/socket.io/;
tls_proxy       |         }
tls_proxy       |
tls_proxy       |         location /api/ {
tls_proxy       |             proxy_pass https://tls_apiui:1337/api/;
tls_proxy       |         }
tls_proxy       |
tls_proxy       |          location / {
tls_proxy       |             proxy_pass http://tls_apiui:3000/;
tls_proxy       |         }
tls_proxy       |     }
ChoonHwa
Hi @huang06 ,
In order to make the TLS2.0 running, there need to have 11 containers up and running. They are
tls_proxy, Tls_core, tls_apiui, tls_rabbitmq, tls_redis, tls_mongo, cvat_proxy, cvat_ui, cvat, cvat_db, cvat_redis.
You can invoke $ docker ps to check the container list.
May I know
  1. Was this the first time and fresh environment TLS2.0 installation?  If it was setup the TLS application before, may I know did you execute below script before rerun the $ ./setup_TLS_docker.sh
    • $ ./cleanup_docker.sh
    • $ ./cleanup.sh
  2. Were you using sudoer to run the installation script?
