Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
405 Discussions
can you provide me the requirements-gpu.txt using in the installation of tls
fa2233
see subject
fa2233
i only find the requirements.txt for CPU setting .  is this file the same as requirements-gpu.txt
Jia-Shing_W_Intel
No, those are different files. requirements-gpu.txt got removed in the 2.2.1 release, and I am trying to find out why for you. Thank you for your patience.
Jia-Shing_W_Intel
According to the TLS engineer, "The requirement-gpu.txt is remove in 2.2.1 is because the docker setup only support TLS run In CPU." Sorry about the inconvenience...
JinPei_N_Intel
Currently, TLS only support training in CPU.  Sorry that we could not provide the requirements-gpu.txt, it will causes the setup not compatible. Sorry for the inconvenience.
