Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
401 Discussions
cannot run influxBDConnecter test.go file
Jerry4_Liu
Hi all,
I have successfully installed EII software package and dcker-compose up
but when I use go run to run test.go file under the InfluxDBConnecter folder , they always appear the "cannot find package "configmgr/eia configmgr" in any of: /usr/lib/go-1.10/src/" and other warnings.
So I would like to ask if anyone else has the same problem or has a solution?
-Jerry
Sahira_Intel
I see the "cannot find package EIIMessageBus/eiimsgbus" error. What version of CMake do you have installed on your system? The EII/OEI message bus relies on CMake v3.11+. Follow these instructions to install the correct version of cmake:
# Remove old CMake version
sudo apt -y purge cmake
sudo apt -y autoremove
# Download CMake
wget https://cmake.org/files/v3.15/cmake-3.15.0-Linux-x86_64.sh
# Installation CMake
sudo mkdir /opt/cmake
sudo cmake-3.15.0-Linux-x86_64.sh --prefix=/opt/cmake --skip-license
# Make the command available to all users
sudo update-alternatives --install /usr/bin/cmake cmake /opt/cmake/bin/cmake 1 --force
Sincerely,
Sahira
Sahira_Intel
Hi Jerry,
I apologize for not responding sooner - I am looking into this issue and will get back to you shortly.
Sincerely,
Sahira
Sahira_Intel
# Download CMake
Sincerely,
Sahira
Jerry4_Liu
Hi Sahira,
I try to use the sudo cmake-3.15.0-Linux-x86_64.sh --prefix=/opt/cmake --skip-license this command
but it still show this information sudo: cmake-3.15.0-Linux-x86_64.sh: command not found
-Jerry
