Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
420 Discussions
eci-ld-ethercat ld /usr/bin/ld ld run timessss
junjuns
eci ld ethercat : /usr/bin/ld : cannot find -lethercat:NO such file or directory
-L /lib/x86_64-linux-gun -wl -rapth,/lib/x86_64-linux-gun \
not find ethercat.so lib
junjuns
CC = gcc
CFLAGS = -Wall -O3 -g -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables
LIBS = -lm -lrt -lpthread -lethercat -Wl,--no-as-needed -L/usr/lib
TARGET = test
SRCS = $(wildcard *.c)
OBJS = $(SRCS:.c=.o)
$(TARGET):$(OBJS)
$(CC) -o $@ $^ $(LIBS)
clean:
rm -rf $(TARGET) $(OBJS)
%.o:%.c
$(CC) $(CFLAGS) -o $@ -c $<
Is there a sample project file for this demo, app link to ethercat for development
junjuns
CC = gcc
TARGET = test
$(TARGET):$(OBJS)
clean:
%.o:%.c
junjuns
Recompile ethercat lib to ethercat.so Ethercat.so.1 Ethercat.1.0.0
sudo cp ethercat.so /lib/x86.. /
Iffa_Intel
these documents might help regarding the EthercCAT use case:
1. IgH EtherCat Master Stack
2. Real Time Data Agent
Cordially,
Iffa
Iffa_Intel
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
