Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
403 Discussions
how to add new node to etcd cluster, master node (LAN), new node (outside the LAN)
fa2233
how to add this new node to etcd cluster or i can do this only by azure ?
Murni_J_Intel
Hi @fa2233
You can refer to the user guide section 15.2 there will be a step on how to add the node to etcd cluster. Both of the node should be able to talk to each other in order to load the configuration from master to worker node.
