Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
341 Discussions
why there hasn't one single 64-bit assembler sdk by intel
fairyfoxhujiujiu
emm ..... for getting 64-bit assembler and 64-bit assembler language article for personal fun , has been searching around again and again ............ finally I find a fact that I can get nothing about it ...........
so , as intel can create such more softwares and hardware equipments that can be in personal use , why just 64-bit assembler program resources can't be found ??
or if not on intel , where else can I find other 64-bit assembler sdk ??
JesusE_Intel
Hi fairyfoxhujiujiu,
I recommend posting your question on the compiler forums for an accurate answer. There is a similar discussion that may be helpful to you. Solved: Assembly Language Programming - Intel Communities
Jesus
JesusE_Intel
Jesus
JesusE_Intel
