Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
421 Discussions
xenomai ethercat ec_generic not run
junjuns
xenomai ethercat not ec_generic.ko eci-user@eci-intel-24f9:/usr/src$ uname -a Linux eci-intel-24f9 5.15.129-intel-ese-standard-lts-dovetail+ #1 SMP PREEMPT IRQPIPE Tue Apr 16 09:42:19 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux e10001e not PACKAGE_NAME="ighethercat-dkms" PACKAGE_VERSION="1.5.2" BUILD_EXCLUSIVE_KERNEL="^((5\.(1[05])\.)|(6\.1\.))" CLEAN="make -C ${kernel_source_dir} M=${dkms_tree}/ighethercat-dkms/${PACKAGE_VERSION}/build clean" BUILT_MODULE_NAME[0]="ec_master" BUILT_MODULE_LOCATION[0]="master" DEST_MODULE_LOCATION[0]="/updates/dkms" BUILT_MODULE_NAME[1]="ec_igb" BUILT_MODULE_LOCATION[1]="devices/igb" DEST_MODULE_LOCATION[1]="/updates/dkms" BUILT_MODULE_NAME[2]="ec_igc" BUILT_MODULE_LOCATION[2]="devices/igc" DEST_MODULE_LOCATION[2]="/updates/dkms" BUILT_MODULE_NAME[3]="ec_dwmac_intel" BUILT_MODULE_LOCATION[3]="devices/stmmac" DEST_MODULE_LOCATION[3]="/updates/dkms" MAKE[0]="./configure --with-devices=8 --enable-kernel --with-linux-dir=${kernel_source_dir} --disable-eoe --enable-sii-assign --enable-hrtimer --enable-cycles --enable-igb --enable-igc --enable-stmmac --enable-generic --disable-8139too --disable-r8169 --disable-e100 --disable-e1000 --disable-e1000e --disable-tool --disable-userlib && make -C ${kernel_source_dir} modules M=${dkms_tree}/ighethercat-dkms/${PACKAGE_VERSION}/build" MAKE_MATCH[1]="dovetail" MAKE[1]="./configure --with-devices=8 --enable-kernel --with-linux-dir=${kernel_source_dir} --disable-eoe --enable-sii-assign --enable-hrtimer --enable-cycles --enable-igb --enable-igc --enable-stmmac --enable-generic --disable-8139too --disable-r8169 --disable-e100 --disable-e1000 --disable-e1000e --disable-tool --disable-userlib --enable-rtdm && make -C ${kernel_source_dir} modules M=${dkms_tree}/ighethercat-dkms/${PACKAGE_VERSION}/build" AUTOINSTALL="yes"
Iffa_Intel
In order for us to replicate this issue, could you:
  1. elaborate further your issue
  2. which ECI Ethercat guide or sample are you using
Cordially,
Iffa
junjuns
eci 3.2 xenomai system
ethercat xenomai .
ko file not ec_generic.ko
Iffa_Intel
This ECI guide/sample is specific for ECI Xenomai and EtherCAT use case: Intel® Edge Controls forIndustrial (Intel® ECI) - Motion Control on Xenomai EtherCAT*
It seems that your Xenomai has been correctly validated:
Perhaps you need to check and validate your EtherCAT installation and its setup.
You may refer to the guide I mentioned above for this purpose.
Cordially,
Iffa
Iffa_Intel
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
