Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
BVH Data
Al_N_
Will or is it possible to get the memory address and size and layout of the BVH data so it can be used, for example, on a GPU?
SvenW_Intel
Look at the bvh_access tutorial. It demonstrates a way of accessing the internal BVH for triangle data. However, the BVH layout might change between releases.
You can also use the internal BVH builders to build your own BVH with your own layout. See bvh_builder tutorial on howto do this.
Al_N_
Thank you :)
