I'm running collision tests between two triangular meshes in embree4. The rtcCollide function only accepts GEOMETRY_TYPE_USER as input. I got it to work and successfully find intersections between my meshes but noticed significant increase in build times for the BVH.
When creating a BVH for raytracing with the same geometry, I can use GEOMETRY_TYPE_TRIANGLE and the BVH is built almost instantaneously.
Here are the results of the rtcCommitScene for a 25k tris mesh
GEOMETRY_TYPE_USER : 14.3882 ms
GEOMETRY_TYPE_TRIANGLE : 0.0342 ms
The relevant code below. Do you have any ideas why this is the case?
Collision:
void createBaseMesh(float vertices[], int verticesLength, int faces[], int facesLength)
RTCDevice device = rtcNewDevice(NULL);
RTCScene scene = rtcNewScene(device);
rtcSetSceneBuildQuality(scene, RTC_BUILD_QUALITY_LOW);
rtcSetSceneFlags(scene, RTC_SCENE_FLAG_DYNAMIC);
meshes.clear();
std::unique_ptr<Mesh> baseMesh(new Mesh());
baseMesh->x_.resize(verticesLength / 3);
baseMesh->tris_.resize(facesLength / 3);
int j = 0;
for (int i = 0; i < verticesLength; i += 3) {
baseMesh->x_[j].x = vertices[i];
baseMesh->x_[j].y = vertices[i + 1];
baseMesh->x_[j].z = vertices[i + 2];
j++;
j = 0;
for (int i = 0; i < facesLength; i += 3) {
baseMesh->tris_[j].v0 = faces[i];
baseMesh->tris_[j].v1 = faces[i + 1];
baseMesh->tris_[j].v2 = faces[i + 2];
j++;
RTCGeometry geom = rtcNewGeometry(device, RTC_GEOMETRY_TYPE_USER);
unsigned int geomID = rtcAttachGeometry(scene, geom);
rtcSetGeometryUserPrimitiveCount(geom, baseMesh->tris_.size());
rtcSetGeometryUserData(geom, (void*)(size_t)geomID);
rtcSetGeometryBoundsFunction(geom, triangle_bounds_func, nullptr);
rtcSetGeometryIntersectFunction(geom, NULL);
rtcSetGeometryOccludedFunction(geom, NULL);
rtcCommitGeometry(geom);
rtcReleaseGeometry(geom);
meshes.push_back(std::move(baseMesh));
rtcCommitScene(scene);
rtcCollide(scene, scene, CollideFunc, &sim_collisions);
rtcReleaseScene(scene);
rtcReleaseDevice(device);
Raytracing:
void RaytracerTest(float vertices[], int verticesLength, int faces[], int facesLength)
RTCGeometry geom = rtcNewGeometry(device, RTC_GEOMETRY_TYPE_TRIANGLE);
float* vb = (float*)rtcSetNewGeometryBuffer(geom,
RTC_BUFFER_TYPE_VERTEX, 0, RTC_FORMAT_FLOAT3, verticesLength * sizeof(float), 3);
memcpy(vb, vertices, verticesLength * sizeof(float));
unsigned* ib = (unsigned*)rtcSetNewGeometryBuffer(geom,
RTC_BUFFER_TYPE_INDEX, 0, RTC_FORMAT_UINT3, facesLength * sizeof(unsigned), 1);
memcpy(ib, faces, facesLength * sizeof(unsigned));
