Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
288 Discussions
One sided triangle intersection only
Tony_M_2
Is there a flag to tell Embree to only return hit intersections for "one sided" triangles
I.E. If the triangle's normal was pointing away from the casting ray, opposed to if they were in opposite directions.
Al_N_
I don't believe so. You need to use the filter function and test which side of the triangle was hit and discard those hitting the wrong side.
SvenW_Intel
Compile Embree with the RTCORE_BACKFACE_CULLING cmake option enabled, and all back-facing triangle will be ignored.
