Intel® Enpirion® Power Solutions
Interact with Intel® product support specialists on Intel® Enpirion® DC-DC Step-Down Power Converters
This forum offers only peer-to-peer support. Thank you!
230 Discussions
EM2130 I2C is required for 0.8@30A or not?
Vyshnav
Hi Intel Team,
We are looking for a regulator which can source 0.8V@30A core voltage required for our chipset and found that EM2130L02QI suits our requirement. To get the required output ie: 0.8V@30A, what hardware configuration needs to be done. ? We would like to avoid any software programming overhead so, Whether I2C configuration is required for this IC to get this particular output.? Please provide reference design if available and support us go ahead with this part.
Best Regards, Vyshnav Krishnan
Mostafa_Intel_AE
Hello Vyshnav,
There is no need to rout the I2C traces for that regulator to make it work., its already programed and you can select the required output voltage by inserting a resistor on RVSET pin.
Attached is a ref schematic for EM2130, so you can copy that design.
Feel free to share your EM2130 schematic for the review and i will be happy to do that.
Mostafa
Mostafa_Intel_AE
Hello Vyshnav,
Mostafa
Vyshnav
Hi Mostafa Sir,
Thank you so much for your quick response. I would like to clarify one more doubt regarding this chip-set.
We are planning to provide the same input 5V supply to  VCC and PVCC pins of the IC. This will be fine or not.?
Vyshnav Krishnan
Mostafa_Intel_AE
Hello Vyshnav,
Yes, there is no issue to use same supply for both PVCC and VCC signals, but we recommend to insert a FB in between these two pins and adding extra 10uF to  VCC to reduce the noise coupling.
Mostafa
Vyshnav
Hi Mostafa Sir,
Our chip-set vendor wanted to simulate all I2C interface functionality for verification purpose. As there is I2C interface in EM2130 chipset, they wanted us to provide IBIS model for this IC. Where can I find IBIS model for this chipset. ? Could you please support for the same.?
Vyshnav Krishnan
Vyshnav
Hi Mostafa Sir,
Could you please support for my previous query regarding IBIS model.
Thanks & Regards,
Vyshnav Krishnan
Mostafa_Intel_AE
Hello Vyshnav,
I checked internally and unfortunately Enpirion doesn't support IBIS model requests.
Mostafa
Vyshnav
Hi Mostafa Sir,
Thank you for your response. I'll share the schematics once the review is done. I request you to check it and provide your feedback.
Vyshnav Krishnan
Mostafa_Intel_AE
Hi Vyshnav,
Sure, please feel free to share your schematic once it done and i will do the required review.
Mostafa
Vyshnav
Dear Mostafa Sir,
Please review attached schematics and provide your valuable feedback.
Vyshnav Krishnan
Mostafa_Intel_AE
Dear @Vyshnav ,
I only have two comments:
  1. Please increase the output capacitance as shown below since this is the core rail
    1. update Rtune to 392R
    2. Cout=4x100uF+4x47uF+2x470uF
  2. Please Insert 10uF to VCC signal as shown
Mostafa
  1.
Vyshnav
Hi Mostafa Sir,
Thank you so much for your review feedback and for sharing the simplis model. I'll update the changes.
I would like to let you know that we have used EM63A0QI for  1.1V, 12A and 1.8V ,12A. If you could review that as well, it will be of great help.
Vyshnav Krishnan
Mostafa_Intel_AE
Hi @Vyshnav ,
Sure, please fell free to share the schematic and we will be happy to review.
Mostafa.
Vyshnav
Hi Mostafa Sir,
Thank you so much. Please find the attached schematics of both 1.1V and 1.8V regulators.
Kindly go through it and provide your valuable feedback.
Vyshnav Krishnan
Mostafa_Intel_AE
Hi @Vyshnav ,
Schematic are okay, but I have only few modification as shown below for optimization.
Same modification for both 1.1V and 1.8V rails.
Mostafa
Vyshnav
Dear Mustafa Sir,
Apart from IBIS model any other simulation model is available for this IC.? If yes, I request you to share the same.
Thanks & Regards,
Vyshnav Krishnan
Mostafa_Intel_AE
Dear @Vyshnav ,
Yes, Attached is  the simplis model for EM2130.
Mostafa
