Intel® Enpirion® Power Solutions
Interact with Intel® product support specialists on Intel® Enpirion® DC-DC Step-Down Power Converters
This forum offers only peer-to-peer support. Thank you!
230 Discussions
EN6338QI Sync pin - Spread Spectrum Clock Support
SNeye
I see that the datasheet for the EN6338QI says it supports feeding in an external clock. I don't see any specific mention of support for a clock input that is spread spectrum or non fixed  frequency.
In other datasheets, such has the EN6337QI, the datasheet specifically calls out the min/max allowable sync frequency as well as the max repetition rate.
Does the EN6338QI support a spread spectrum clock input on its sync pin, and if so what are the min/max frequencies supported and what is the max repetition rate supported?
Thanks!
Mostafa_Intel_AE
Hello @SNeye ,
Actually EN6338QI uses same die design as EN6337, so both of them has same sync feature specs.
So please use the same function limits as EN6337.
I will open an internal ticket to update the sync specs of EN6338 inside the datasheet.
Mostafa
Mostafa_Intel_AE
Hello @SNeye ,
Mostafa
