I would like to configure this part as a current source with set point control on SS pin. Does Intel offer any documentation to support such application ? I have successful implemented such design on similar topology converters. Those converters are less integrated and likely not quite as efficient as the EN6360QA.
There is not much information on the built-in compensation network, which I would need. If this is proprietary, could Intel offer an application solution to support this effort. I do not require dynamic operation. Output step responses in the 10-msec range should be adequate.
Also, can an LTspice model be provided ?
If its not possible to move forward thru this support forum, I would appreciate being able to talk with someone directly at Intel to discuss further.
Sean
Hello Sean,
Sorry for late response.
Can i know what EN6360QA will be used for, does it will power LED array?
Currently Intel /Enpirion team doesn't have the required documentation, but I can help to provide a simulation model and some analysis if i know more about the project nature?
I can send you a personal email if you can't provide any information on public.
Mostafa
Hello Mostafa,
Thank you for following up on this issue. Do to the competitive nature of our product, I prefer to take you up on your offer to discuss thru email.
Waiting to hear back from you.
Sean
Hello Mostafa
I sent few emails over the last week to the support email provided.
Did you have time to look at this ?
I would like to get LTspice model of EN6360QA and PCB footprints (Cadence PCB Editor)
If you have gerber file of eval board that could also be helpful
In addition on the design level, if you could recommend any support of adding an LC filter at the output to aid in attenuating further residual switching noise ?
Sean
- Tags:
- Hell
