Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
EN63A0QA parallel operation
Jump to solution
Good morning,
Could anyone tell me if we need to connect Enable pin together between master and slave component?
Same question for SS pins for parallel operation (each component with a capacitor or only one capacitor for all).
Accepted Solutions
Highlighted
No, you no need to connect all together , but it is based on your application how do you want to use the Parallel Operation. I believe parallel operation mainly used to get the more current output right ? In that case do you want to enable one chip after other based on the your feedback ? Same apply to SS pin as well .
Note : Please make power sequence you follow as per the datasheet.
Highlighted
Highlighted
Ok, I don't have any "special" feedback about that, it was just to know if there is a requierement about that.
