Intel® Enpirion® Power Solutions
Interact with Intel® product support specialists on Intel® Enpirion® DC-DC Step-Down Power Converters
This forum offers only peer-to-peer support. Thank you!
227 Discussions
EN63A0QA parallel operation
MBaqu
Good morning,
Could anyone tell me if we need to connect Enable pin together between master and slave component?
Same question for SS pins for parallel operation (each component with a capacitor or only one capacitor for all).
SreekumarR_G_Intel
No, you no need to connect all together , but it is based on your application how do you want to use the Parallel Operation. I believe parallel operation mainly used to get the more current output right ? In that case do you want to enable one chip after other based on the your feedback ? Same apply to SS pin as well .
Note : Please make power sequence you follow as per the datasheet.
SreekumarR_G_Intel
MBaqu
Ok, I don't have any "special" feedback about that, it was just to know if there is a requierement about that.
