Similar to the stability tool spreadsheet, is there an electrical tolerance analysis spreadsheet for this part too? I would like to perform a tolerance analysis wherein I could get the output voltage tolerance limits over temperature as well. This would also take into account the effect of the voltage feedback that we use.
Hello Ellen,
Unfortunately Enpirion doesn't have a tool to calculate the voltage tolerance.
But the measurement shows that the max tolerance over temp/Load/line changes is +/-3%.
Mostafa
