Intel® Enpirion® Power Solutions
Interact with Intel® product support specialists on Intel® Enpirion® DC-DC Step-Down Power Converters
This forum offers only peer-to-peer support. Thank you!
218 Discussions
Help in translating lines of code verilog to vhdl
CHerb4
Greetings, first to say that I am new to the forum and I really do not know if this is the correct section for this type of questions.
I have limited knowledge in vhdl but I am totally new in verilog. A couple of days ago I try to translate a project from verilog to vhdl, for this I am using a translator, but even so I am finding the following lines that I can not translate to vhdl.
`define SBUSRANGE 32*idx+31:32*idx // Incrementing indexes within generate below   wire [31:0] sdma_dq = i_sdma_dq[`SBUSRANGE];
Any help is very welcome, thanks in advance.
GuaBin_N_Intel
Maybe you can try out line below:
=> signal [31:0] sdma_dq : std_logic_vector ((32*idx + 31) downto (32*idx));
