Intel® Enpirion® Power Solutions
Interact with Intel® product support specialists on Intel® Enpirion® DC-DC Step-Down Power Converters
This forum offers only peer-to-peer support. Thank you!
231 Discussions
I am working on MAX 10 FPGA device & not going to use inbuilt ADC functionality. For VCCA, VCCA_ADC & ADC_REF pins what is the voltage needs to be connected? Presently we have in our board 1.2V for FPGA core & 3.3V for IO's.
MMano5
These VCCA pins can be connected to 3.3V as i am not using ADC at all, Please help me to understand.
AnandRaj_S_Intel
Yes,
VCCA-> Connect these pins to a 3.0- or 3.3-V power supplies even if the PLL and ADC are not used.
VCCA_ADC -> Tie the VCCA_ADC pin to any 2.5 V power domain if you are not using ADC.and do not tie the VCCA_ADC pin to GND.
 ADC_VREF->If you are not using the external reference, this pin is a no connect (NC).
Anand
MMano5
Thanks for your reply.
I don't have 2.5V in my board & not using ADC , still i need to give VCCA_ADC pin 2.5V ?
Why can't i connect VCCA_ADC to 3.3V?
From my board perspective, 2.5V voltage regulator will add cost to the board unnecessarily. Please help me to understand.
AnandRaj_S_Intel
​Hi,
You can check the Power Supplies Recommended Operating Conditions from data sheet. VCCA_ADC maximum Operating  voltage can be 2.625.
 3.3V is under absolute maximum rating, Device should not operate under in absolute maximum rating, which may cause permanent damage to the device.
Anand
