Intel® Enpirion® Power Solutions
Interact with Intel® product support specialists on Intel® Enpirion® DC-DC Step-Down Power Converters
This forum offers only peer-to-peer support. Thank you!
229 Discussions
Right resistor setup for +4.0v output EM2120
ЮБаду
Hi, I am going to use EM2120H01QI Intel power solution product for powering custom FPGA based design. Target output voltage is +4.0v, maximum output current is 16A. The +4v is not standard output voltage, and there is no directions in datasheet which values I have to use for output violtage setup resistor network. Whould You give me resistor values for RVSET, R1DIV and R2DIV resistors for output voltage +4.0v ?
Regards, Jury
Mostafa_Intel_AE
Hi Jury,
No need to scale Read_IOUT.
Only READ_VOUT value needs to be multiplied by 2.
Mostafa
Mostafa_Intel_AE
Hello Jury,
To generate 4V from EM2120H01QI device you will need to have:
RVSET=5.36kΩ
R1DIV=2KΩ
R2DIV=665Ω
But please note that you will need to scale the Vout reading value through the PMBUS by 2, you can ignore that if you are not using PMBUS to read Vout value.
Mostaaf
ЮБаду
Mostafa, thanx for yoyr reply, one more question : do I need to scale value for READ_IOUT command or not?
Jury.
Mostafa_Intel_AE
Hi Jury,
Mostafa
