Dear Support,
Currently, I'm using the EN6347 to power an FPGA.
Do you have any Bode Diagram example for this kind of Step-Down converter? (Gain Margin, Phase Margin, crossover frequencies)
I didn't found any information in the datasheet and I would like to compare the shape with an typical performance shape.
Configuration:
Vin = +5V, Vout =3.3V, Iout = 800 mA (PWM Mode)
Kévin
Hello Kevin,
Yes, you can use Enpirion stability tool( Attached) to predict the gain /phase margin.
Mostafa
Dear Support,
Thanks for the answer.
Kévin
Topic Options
