Intel® Enpirion® Power Solutions
Interact with Intel® product support specialists on Intel® Enpirion® DC-DC Step-Down Power Converters
This forum offers only peer-to-peer support. Thank you!
229 Discussions
What will happen if VCC voltage is not in the recommended range?
Daphn
Hi there,
Per datasheet, the typical recommended voltage value is 0.8 - 0.94V. What if VCC supplied with 0.6V? Degraded performance or doesn't work at all?
Thanks in advance.
SreekumarR_G_Intel
Hello ,
Apologize for the delay in response
Startix 10 internally do have power management module and as you know there is power sequence monitor as well internally embedded into the S10 module.
If the VCC supply of group 1 which is not 90% of nominal voltage , the POR of the S10 is not going to assert. Hence I believe it would remain in off-state.
Thank you ,
Sree
