Intel® Enpirion® Power Solutions
Interact with Intel® product support specialists on Intel® Enpirion® DC-DC Step-Down Power Converters
This forum offers only peer-to-peer support. Thank you!
224 Discussions
Why is our MAX10 FPGA responding to wrong JTAG TCK edge here?
MSchu50
I am not sure which is the right category for this question, i am sorry.
We are InCircuitProgramming two MAX10 devices in a chain on an embedded board via JTAG. That works in general, but sometimes we are experiencing problems.
Our problems can be explained by a misbehaviour of one of the Intel FPGAs. As you can see on the logic analyzer screenshot at 4.374 ms, the FPGA responds to a rising TCK edge as if it was (also) a falling one.
Is this a known behaviour? What are possible reasons for that? What can we do against it?
ShafiqY_Intel
Hi MSchu50,
Have you pull-down TCK pin to 1kOhm?
MSchu50
Hi WolfGang,
thanks for your reply,
we have tried with and without 1K PullDown on TCK (and 1K PullUp on TMS).
Unfortunately it didn't solve the problem.
ShafiqY_Intel
How much the TCK Frequency you are using?
My recommendation, use 6MHz (default value) for TCK Frequency.
And check this pins:
  • TDI & TMS = pull-up (10K Ohm)
  • TCK = Pull-down (10K Ohm)
  • TDO = leave unconnected or pull-up
Cheers
MSchu50
Thank you for the suggestions!
Our TCK Frequency is quite slow, around 2 MHz. Maybe this is why we treated it as a "slow" signal and didn't care about enough.
In the meantime our hardware engineeres had a closer look on the (analog side of the) problem and found "something". We are not sure yet but i seems our layout is "too bad" and we ignored termination issues.
ShafiqY_Intel
Hi MSchu50,
I hope my previous responses have been sufficient. Thus, I request to close this forum at this time.
MSchu50
Hi WolfGang,
yes, thanks, please close. Or can I do anything to close it?
