I want to create a script for the preloader with BSP Editor Tool.
It’s the first time I use the BSP Editor.
When I created a new HPS BSP I chose the directory by default and I got the following error:
The preloader settings directory is invalid in BSP Editor. Please select a directory which contains hps.xml and emif.xml
What can I do ?
Thanks for your help.
Jerome
You have to select the handoff folder which is generated from your Quartus project compilation.
In BSP editor, you should set this directory to:
<YOUR PROJECT LOCATION>\hps_isw_handoff\soc_system_hps
