Hi Intel/Altera,
for our current design of safety related project we would need the official FIT values for following IC
i couldn't found related value in the reliablilty report 1H 2017. There are some PowerSoC QFN devices listed in the report but no 3.75x3.75x1.9mm 19-pin LGA package.
This data is critical for our design since it must be safety certified, please support us on this matter thank you!
Hello Ruozong,
The FIT values for EN6338QI (MS250BH process) at different temperatures are:
Hope this answer your question.
Mostafa
Hi MOSTAFA,
can you please also provide the FIT rate for 90% confidence level? this data is what weneed for the functional safety evaluation, with 60% conf. level we are not allowed to interpolate for a CAT3 PLd system.
cheears
Ruozong
Hi Ruozong,
Can i know what is the type of the application, where EN6338QI is not currently supported for automotive applications.
Mostafa
sure, it is an industrial automation application, not automotive.
thanks.
Ruozong
Hi Ruozong,
Attached please find the FIT values for EN6338QI (MS250BH process) at different temperatures at 90% Confidence Level.
Mostafa
Dear Mostafa,
could you please issue an official statement including these data since it need to be showed to authority during the certification process and send to my email?
we can't just take an snapshot from the forum for this purpose:)
thanks in advance!
Best regards
Ruozong
Dear Ruozong,
Unfortunately Intel does not provide official statement or certification about FIT rate numbers.
You can refer to the reliability report (as attached) pages 35-36 for the FIT number for Enpirion Power SoC devices family at Tj=70oC. The FIT number at Tj=70oC (Page 36) in Reliability Report covers EN6338QI, because the same process technology (MS250BH process) is used.
Mostafa
