We are intended to introduce this DCDC Converter in our Newspace projects and need to estimate outgassing and whisker issue
Many thanks in advance
Ottmar H.
Senior Component Engineer
edited to protect personal info
Hello Ottmar,
Unfortunately, EN6347QA is not currently supported for Aerospace application.
Mostafa
Dear Mostafa,
we understand that you are not supporting the EN6347 for space application.
Before we use this part in our designs we would like to do some tests and some theoretical investigations
So it is just our responsibility…..
Material information and whisker estimation is not a typical parameter for space application it is also important for applications in automotive industry.
Therefore I would like to ask you again for these information.
Mit freundlichen Grüßen / best regards
Ottmar H.
Dear Ottmar Heger,
Understand, attached please find the required Material Declaration report.
BTW, you can follow the instructions below to obtain the material declarations reports.
Mostafa
Intel PSG provides MDDS documents for the customers to download and obtain the information they need.
Please refer to our product MDDS for material content in our MDS website for customers to do a self-service.
Find Intel NCLG/PSG material declarations [FMD, part weight, ppm] https://www.intel.com/content/www/us/en/programmable/support/quality-and-reliability/environmental/m...
Find Intel NCLG/PSG DoC compliance letter https://www.intel.com/content/www/us/en/programmable/support/quality-and-reliability/environmental/l...
Intel NCLG/PSG REACH link
https://www.intel.com/content/www/us/en/programmable/support/quality-and-reliability/environmental/r...
Prop65(California) Compliance
If the survey product(s) is/are IC(s). They are usually not frequently handled and does not expose any CA Prop65 substances to consumer.
To view the above website, you have to first register your name in our website below and register an account, then you will be permitted to get the data that you need.
https://www.intel.com/content/www/us/en/my-intel/fpga-sign-in.html?redirect=/content/www/us/en/secur...
Dear Mostafa,
many thanks for providing the materials declaration sheet and even it’s in xml-format it helps.
So 1 question:
From the material declaration sheet it seems that the leadframe has a pure tin plating (>97% tin) What is the whisker mitigation activity strategy with Intel
Ottmar H.
Dear Ottmar,
Below is the quality team feedback:
EN6347QA has matte Tin plating over Cu Alloy 194 leadframe.
Tin Whisker Mitigation Procedure:
Tin Whisker Acceptance Test Results:
No tin whiskers observed after the following three types of preconditioning:
- Thermal cycle test (temperature cycling) : -55°C to 85 °C , 20 minutes soak, for 1000 cycles
- High Temperature / Humidity Storage : 50°C to 60 °C , (80 - 95)%RH, for 6 months
- Ambient Temperature/ Humidity Storage : 20 °C to 30 °C, (30 - 85)%RH, for 6 months
Please let m know, if this answer your question.
Mostafa
