Buongiorno
1)Ho la necessità urgente di programmare le EPLD EP910LC44 e EPM7064LC44
Il mio programmatore LP6+LP-MPU non funziona più, qualcuno può indicarmi una soluzione?
2)Ho richiesto delle licenze a Intel per il software MAX+PLUS Baseline (per hard disk) per poter lavorare sul progetto e compilare anche per altri componenti.
La richiesta è andata a buon fine apparentemente, ma non ho mai ricevuto le licenze!!
Perchè Intel?
Grazie per l'aiuto
Marci
Good morning
1) I have an urgent need to program the EP910LC44 and EPM7064LC44 EPLDs
My LP6 + LP-MPU programmer no longer works, can someone show me a solution?
2) I have requested licenses from Intel for the MAX + PLUS Baseline software (for hard disk) to be able to work on the project and also compile for other components.
The request was apparently successful, but I never received the licenses !!
Why Intel?
Thanks for your help
Marci
Dear Marci,
Thank you for using Intel FPGA Community Forum.
--> Please file a new case. The case will be supported by an appropriate Application Engineer.
Wani
Can I know how you request for the license? Do you received any email showing it is successfully processed?
For your information, you need a valid license to run the MAX+PLUS II software. However, MAX+PLUS II license is no longer available for purchase.
You may request a free license for MAX+PLUS II BASELINE software with limited feature.
https://www.intel.com/content/www/us/en/programmable/f/download/licensing/lic-max2baseline.html
Or you can purchase the Intel Quartus Prime license that includes a full feature of MAX+PLUS II software.
You can refer to software selector.
https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
Thanks!
Wani
