Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
BSP editor not opening in Eclipse
Anu_Jayan
Hi
> I have installed Quartus version 23.2 and Eclipse IDE into the Ubuntu 20.4 system.
https://www.terasic.com.tw/wiki/Getting_Start_Install_Eclipse_IDE_into_Nios_EDS
> I have loaded the FPGA file .sof into the eclipse IDE & generated the "Nios II application & BSP from template".
> I have used "Memory Test" as a template, to generate the project.
> I clicked the Nios II ---> BSP editor option & the BSP editor didn't open, instead it showed an error.
Can anyone help me to solve the issue? Thanks in advance.
Anu Jayan
EBERLAZARE_I_Intel
Can you provide the full Quartus version that you're using? Is it the Pro version?
Anu_Jayan
Yes, I am using Intel Quartus Prime Version 23.2.0 Build 94 06/14/2023 SC Pro Edition.
Anu Jayan
EBERLAZARE_I_Intel
For Quartus 23.2, the Nios® II Processor and Nios® II Embedded Design Suite products are deprecated and will be removed in a future release.
More details:
https://www.intel.com/content/www/us/en/content-details/781327/intel-is-discontinuing-ip-ordering-codes-listed-in-pdn2312-for-nios-ii-ip.html?DocID=781327
Nios V migration guide:
https://www.intel.com/content/www/us/en/docs/programmable/773196/current/overview.html
EBERLAZARE_I_Intel
Do you have any further questions?
Anu_Jayan
EBERLAZARE_I_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
