I'm unable to launch a simulation for a project and I keep getting the following error:
I'm using Quartus Prime Lite Edition 21.1 with a generated free license from Intel "Questa*-Intel® FPGA Starter Edition SW-QUESTA".
Steps taken so far to diagnose/fix:
1. Checked the license is the correct version and the NIC ID matches.
2. Checked the environment variable "LM_LICENSE_FILE" points to the correct file, and made sure the correct file is setup in the Quartus license setup options.
3. Ran "lmutil lmdiag", output shows "This is the correct node for this node-locked license"
4. Re-installed Quartus to make sure I only have the default starter edition installed.
5. Requested new license for the same product and replaced old one.
6. Made sure in EDA Tools, "Questa Intel FPGA" shows as the correct path "C:/intelFPGA_lite/21.1/questa_fse/win64" in my case.
I'm at a loss of how to move forward to resolve this issue. I require this tool to complete a university assignment and my lecturer and the university technicians could not resolve the issue.
Any support would be greatly appreciated.
The following is the Error log from Quartus:
Hi Andrew,
Did you able to resolve this or still need some help?
Anyway, have you tried on diff machine?
Is it possible to use latest std edition? (i think 22.1)
This issue is still unresolved, assistance would be appreciated.
Unfortunately this is the only machine i'm able to test this on, however other students have been able to get theirs working when following the same steps taken.
I've been instructed to use 21.1 as thats the version a lot of the lab sheets are based around, but if the differences are minimal it could be worth a try.
I'm able to provide a copy of the instructions followed for installation so you can see what steps were taken and where things might have gone wrong.
Many thanks,
Andrew.
The step seem pretty correct.
Did you have any background app running when launching Quartus?
Also, sometime antivirus can be affecting the process.
Try to disable it temporary.
May I know if there is any update?
Apologies for the delay in response.
The software is now working, I had given up on it until recently when I tried it again without changing anything since the original post and it works now, it wasn't anything to do with the antivirus etc.
Perhaps there was a large delay for the license to activate?
Andrew.
![](/skins/images/045A6C88D0527A93E76B179D7F5E2AFE/responsive_peak/images/icon_anonymous_message.png)
