Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1277 Discussions
Is there a problem with executing Questa FSE using WSL?
sam135
I have trouble using Questa FSE.
It seems that installation and license registration are ok, because i can run the questiona for a while.(i can see Questa GUI for a while)
However, the Questa ends immediately saying that there is no viewer license.
I tried to use linux version Questa FSE using WSL2 on Windows 11. Will this be a problem?
or, is there anything else i can check?
below is the terminal log when i run questa.
./vsim
Reading pref.tcl
Unable to checkout a viewer license necessary for use of the Questa Intel Starter FPGA Edition graphical user interface. Vsim is closing.
sam135
There was a problem with the license because the mac address in the WSL is not static.
I solved the problem by adding some script to the bashrc.
for example,
wantmac=[mac address you need]
mac=$(ip link show bond0 | awk '/ether/ {print $2}')
if [[ $mac !=  $wantmac ]]; then
    sudo ip link add name bond0 type bond mode active-backup
    sudo ip link set dev bond0 address $wantmac
fi
export LM_LICENSE_FILE=/mnt/e/License/[License file path]:$LM_LICENSE_FILE
I referred to the post below.
SyafieqS
Glad that you have resolved the issue. I am putting this to close pending
