I went through the licensing wizard and generated / downloaded a license file.
The license partially works --
- the host ID matches the NIC ID
- it lists a bunch of AMPP/Megacore functions, all with a 2023.01 expiration.
If I make edits to the license file, these licenses disappear, as expected.
However, I can't run Quartus, and the current license indicates that the "Subscription Expiration" is 2016.02.
Where do I go from here?
Thank you in advance for your help.
Hello
Welcome to Intel forum. Could you help to reconfirm the license setup again. You can refer to link below for more detailed instructions for Setting up a license https://www.intel.com/content/www/us/en/docs/programmable/683472/21-4/licensing-fpga-software-walkth...
I have read through the document. As far as I can tell, I don't have a License Activation Code.
The software is setup properly on my PC. However, the license is not valid (see previous email)
I am very frustrated b/c I have been trying to sort out the licensing for almost a month and a half.
How do I resolve this?
Hi
Thanks for update and apologies for troublesome that you have. May we know, have you purchase Quartus license? To narrow down this issue.
1) Error message screen shot
2) Quartus version use
3) Machine OS information
4) License.dat file
kindly advise the following for checking.
Name :
Email Address :
Company Name :
Company Address :
NICID(Mac Add) :
You can also reply/attach your file in private message.
