Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
License issue on Linux WS
Francesco40
I've restored a linux workstation after an hardware failure, and i'm now reinstalling the quartus environment that was already present on that machine with a node locked license.
Since the maintanaince date in the license file is 2019.03, I have downloaded and installed the 2019.1 version of the tool, with the same license file.
Unfortunately, the license seems to not work. Indeed, goinf to the 'License setup' tab, the HostID type and value show both 'Not found'.
Any hints?
It's a matter of version  (on the previous Linux installation, a RHEL 7.1, I was using 2018.1), or an environment issue? Can you help?
regards,
   francesco
AR_A_Intel
Hello
Welcome to INTEL forum. Could you kindly help check you license setup again. Starting with your OS support, whether your machine is supported or not (OS) by referring to link below:
https://www.altera.com/support/support-resources/download/os-support.html   *Table 3. OS Support for Altera® FPGA Software Versions
AR_A_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
