Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1342 Discussions
Programmer: Kernel mode driver not installed
Niko3
Hi, I'm new with Quartus and have the following problem:
After starting the programmer, click on "Hardware Setup..", select USB-Blaster, and click on "Add Hardware" then in the window plopping up there are two lines.
  1.  Hardware Type: ByteblasterMV or Byteblaster II
  2. Port: Kernel mode driver not installed.
My download cable is named "USB Blaster", no MV nor II. A second possible selection for Hardware Type is EthernetBlaster which certainly is not my cable.
Since some time I'm struggling with programming my EPM3064ATC44. Formerly my USB Blaster was recognized but I had severe problems with Quartus/programmer hang up and could only get out by killing the process via Task Manager. May be, something more has been killed.
I also reinstalled the programmer software which did not change the problem.
What can I do now?
A very frustrated Niko3 is asking for help.
_AK6DN_
Valued Contributor II
Hmmm. Same software for me (QuartusII 13.0sp1 Programmer) and with a USB Blaster plugged in and driver installed, works fine.
I suspect you don't have a USB driver (correctly) installed for your USB Blaster.
My screen shot:
And if I go into my Windows10 Settings / Computer Management / Device Manager, I see the Altera USB device and the installed drivers:
Niko3
One of the two .sys files in your configuration is different from mine. I have edevmon.sys instead of USBPcap.sys and
the provider is ESET instead of FTDI ltd.
I will look for FTDI drivers.
Thank you.
_AK6DN_
You have never stated what operating system you are running on? WIndows or Linux? Exactly what version.
If you want reasonable help you need to state your system configuration exactly, as it matters for software install and issues.
NazrulNaim_Intel
It seems like it is missing the USB blaster driver. Below I will attach the link for the USB blaster driver installation guidance.
Link : https://www.intel.com/content/www/us/en/support/programmable/support-resources/download/dri-usb-b-lnx.html
Hope that answers your question.
Nazrul Naim
NazrulNaim_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, for now I will set this case to Close-Pending.
Nazrul Naim
