Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
Questa License Issue
ganz_1
I'm trying to use Questa IntelFPGA Starter Edition 2024.1. My license file questa.dat is located at c:\license\, and I set c:\license\questa.dat to LM_LICENSE_FILE. When I launched Questa, it failed to checkout a license.
When I run "lmutil lmdiag", it found my license file and seemed like the license is valid. "xxxxxxxxxxxx" below match my NIC-ID.
License file: C:\license\questa.dat
"intelqsimstarter" v2025.11, vendor: mgcld, expiry: 15-nov-2025
uncounted nodelocked license, locked to ethernet address "xxxxxxxxxxxx" starts: 15-nov-2024, expires: 15-nov-2025
This is the correct node for this node-locked license
ganz_1
It turned out there was a conflict with SALT_LICENSE_SERVER.  Suggestion from the following link solved my issue.
Solved: Re: Questa License Issue - Intel Community --  "However, if a salt_license_server enviroment variable is present, because other Siemens software has created it, Questa is only checking this variable and skipping lm_license_file and mgls_license_file variables. The solution is to add the Questa license file to the salt_license_server entry."
ganz_1
paveetirrasrie_Intel
I’m glad that the forum helped to addressed your query, I now transition this thread to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Otherwise, the community users will continue to help you on this thread.
Thank you.
