Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
Questa license server on linux
danyvak
Hi
I try to setup a license server on linux for Questa.
We have license file, which I modified according the instructions
I was able to get lmgrd running, setup a LM_LICENSE_FILE=1717@dev1 (this is a server name)
After that I run a diagnostics ./lmutil lmstat
License file: 1717@dev1.corp.devalore.com
"msimviewer" v2022.090, vendor: mgcld, expiry: 30-sep-2022
vendor_string: 6DDBFAD6
License server: dev1.corp.devalore.com
floating license starts: 1-aug-2022, expires: 30-sep-2022
This license can be checked out
mgls_ok also returns a "good" result, for example:
danyvak@dev1:/local/shared/intelFPGA_pro/questa_fe/linux_x86_64$ ./mgls_ok msimhdlsim
Checking availability of "msimhdlsim".
8:28:19 (mgcld) OUT: "msimhdlsim" danyvak@dev1.corp.devalore.com
License granted through "msimhdlsim".
8:28:19 (mgcld) IN: "msimhdlsim" danyvak@dev1.corp.devalore.com
And I get the same message for all features
but when I try to run a ./vsim I get:
danyvak@dev1:/local/shared/intelFPGA_pro/questa_fe/linux_x86_64$ ./vsim
Unable to checkout a license. Make sure your license file environment variable (SALT_LICENSE_SERVER, MGLS_LICENSE_FILE, LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Unable to checkout a license. Vsim is closing.
** Error: Invalid license environment. Application closing.
I really don't know how to proceed. The Linux version is Ubuntu 18.04
AR_A_Intel
Hi
Welcome to Intel forum. Per my understanding, Ubuntu 18.04 is not an officially support OS for Questa. An unsupported platform means that some things may work, but others not, and we won't put any resources into debugging or diagnosing. For more details refer the below link,
https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/os-support.html?wapkw=operating%20system%20support
AR_A_Intel
Hi
danyvak
AR_A_Intel
With your confirmation. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
