Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1344 Discussions
Setting window of quartus is not displayed fully: Resizing of setting window (only) doesn't work
qaziullah
I have installed quartus 20.1 on ubuntu 20.04 and I having issue with the setting window being not displayed fully. screen shot of the window is attached here.
the portion below the drawn line is not being displayed on screen but it did get in picture when I took screen shot.
the portion below the line contain apply and ok buttons to confirm the any changes in setting and I need this these buttons.
Also only the setting window cannot be resized (resize option is not working for it).
Help will be appreciated.
KennyTan_Altera
KennyTan_Altera
any update?
qaziullah
@KennyTan_Altera  the link is asking to delete the following folder on the computer
1. "~/mw " .
2.  " /tmp/mw_<username>"
I don't hava "~/mw " or a " /tmp/mw_<username>" directory on my computer.
So the problem is still unresolved.
KennyTan_Altera
Can you try the below?
cd to home/<user>/.altera.quartus  rename the quartus2.ini and quartus2.req for linux
and reopen the quartus. this will reset the initial setting of the quartus prime.
Qazi_Shahid
I only have quartus2.qreg file in the folder.
what should I rename it to?
KennyTan_Altera
you can rename it to anythings. This renaming purposes is just for backups in case you need it back in the future.
KennyTan_Altera
any further queries?
KennyTan_Altera
We do not receive any response from you to the previous reply that we have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
AndyE
I have exacly the same problem using Ubuntu 24.04 and Quartus Prime lite 23.1. It is impossible to apply any change since I cannot see the buttons.
I tried what was explained above but I cannot find directory with the name mentioned. Also, I could not find the quartus2.ini and I the command "cd to home/<user>/.altera.quartus" tell me that this directory does not exist (I do not see it too).
Is there anything else I could do ? I mean, I could not follow any of the given instruction as it does not apply to me looks like. I mostly tried to change settings in Ubuntu but nothing worked.
Thank you in advance for your answer !
AndyE
For the information, after very long hours of trying to fix this issue, I finally just arrived to the conclusion that the easiest way is to see the buttons is to connect an additional screen to my laptop (which is old and have a low resolution).
On the bigger screen, I could see the buttons and start working. However, I am still keen on knowing how to solve the issue because it is not the most practical to do this in my configuration.
