Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1010 Discussions
Simulation waveform editor of Quartus 19.1 problem
EMona89
Why in using the "Simulation waveform editor" of Quartus 19.1 gives me that the excutable file of modsim is not found. I don't want to use modelsim, I want to use .vwf files to run the simulation.
Must I install Modelsim also?
RichardTanSY_Intel
Go to Assignments > Setting > EDA Tool Settings, then specify the simulation tool used in your Quartus project.
By default, it was selected as Modelsim. Do note that you can only select simulator tools supported by Quartus.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
EMona89
What should I select to simulate the (.vwf) files?
RichardTanSY_Intel
You select the simulator (supported by Quartus) that you need to simulate the (.vwf) files.
You may need to set the path to the simulator executables specified in the Quartus tool under Tools > Options >EDA Tool Options
Though, Intel highly recommend to use Modelsim-Intel Edition for use with the Simulation Waveform Editor.
Richard Tan
RichardTanSY_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
